Which engine will work? |
stags14 |
Jun 21 2006, 06:23 AM
Meep Meep Meep Meep Meep!!! Group: Members Posts: 84 Joined: 24-February 05 From: Amherst, NY Member No.: 3,653 |
I can get a screaming deal on a brand new GM crate engine. Being the novice that I am with my 914, would any of these engines be a decent choice???
12499679 Ecotec 2.2L Production Engine This 4 cylinder Crate Engine (RPO L61) has the following features: DOHC with Sequential Fuel Injection Bore is 86.00 mm and Stroke is 94.60 mm with 10:1 compression ratio 140 Horsepower @ 5600 RPM and 150 lb-ft @ 4000 RPM torque This engine powers the current Saturn Ion, Chevrolet Cavalier, Pontiac Sunfire and Grand Am, Oldsmobile Alero, and Chevrolet Malibu This production engine includes: exhaust manifold, intake manifolds, injectors, fuel rail, balancer and water pump Technical Notes: Pulley, belt, p/s pump, a/c pump, starter, alternator, and engine cover, are not included with this engine 12499469 3800 Series II Supercharged Production Engine This supercharged V-6 Crate Engine (RPO L67) features the following: 240 Horsepower @ 5200 RPM and 280 lb-ft @ 3600 RPM torque Sequential fuel injection Bore is 96.52 mm and Stroke is 86.36 mm with 8.5:1 compression ratio Iron Block, Iron Heads and Hydraulic roller design camshaft This engine powers the Buick Park Avenue, Chevrolet Monte Carlo This production engine includes:exhaust manifolds, intake manifold, supercharger, injectors, fuel rails, balancer, water pump and flywheel Technical Notes: Pulley, belt, p/s pump, a/c pump, starter, alternator and engine cover are not included with this engine 12499466 Ecotec 2.0L Supercharged Production Engine This supercharged 4 cylinder Crate Engine (RPO LSJ) features the following: DOHC with Sequential Fuel Injection Bore is 86.00 mm and Stroke 86.00 mm with 9.5:1 compression ratio 205 Horsepower @ 5600 RPM and 200 lb-ft @ 4000 RPM torque This engine powers the Saturn ION Redline This production engine includes: exhaust manifold, intake manifold, injectors, fuel rail, balancer, water pump and flywheel Technical Notes: Pulley, belt, p/s pump, a/c pump, starter, alternator, and engine cover are not included with this engine |
Brad Roberts |
Jun 21 2006, 11:08 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Lots of conversion talk occurring on other forums surrounding the ECO engines.
I personally would go for the Supercharged version. Get some measurements on it. WRX914, do you work for Renegade? B |
stags14 |
Jun 21 2006, 11:10 AM
Lo-Fi Version | Time is now: 27th September 2024 - 09:21 AM |
