Body filler, Do NOT use plastic |
tdgray |
Oct 2 2003, 08:39 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Here is prime example of 1) how not to fix a rust spot. 2) NEVER NEVER NEVER use plastic body fillers. I'm sure at one time this was a small hole or rust spot that was fixed with plastic filler (Bondo and the like). Plastic fillers attract water and hold it thereby rusting any and all unprotected metal underneath. Not to mention that this was a very poor repair job in the first place.
Attached image(s) |
Katmanken |
Oct 3 2003, 01:35 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Actually, I don't think that the foam just collects moisture/water/debreis. I think it chemically reacts with steel.
The reason that I say that is my 73 Superbeetle rusted between the rear window and the side window and in the storage area under the rear window. It rusted from the inside out and only where there was foam. I never had any moisture inside the car - but there was expanded foam! Ken |
Lo-Fi Version | Time is now: 27th September 2024 - 04:16 PM |
