How much will it cost?, A price quote from Brad |
r_towle |
Oct 7 2003, 07:16 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Brad,
I will deliver you a chassis all modified, ready to go with an original six engine mount, cage and rough body work complete. I want you to find, install, tweek, road test, and finish the following 3.6 motor /6 G50 tranny with limited slip bigger axles and CV joints (you spec) cable shifter Engine management (original kit for the 3.6) Front mount oil cooler (I will leave the size up to you, basically I will cut the front bumper and add the lower GT valance) What else?? Body and interior I will take care of as well as the cage, though I could be convinced to let Tony do it while its there, otherwise I may stick with Chris because he is close enough for me to go down there, and I want to do a few un conventional things here. then I will come get it. So, no shipping for you, just find and install the basic list above. |
r_towle |
Oct 8 2003, 08:41 PM
ok,
how about heat? Can I still have some sort of heat with a 3.6 and headers? I am thinking of some way to steal heat from the oil cooler setup... I will be welding up the heater tube holes and providing a new tunnel down the passenger side next to the existing shifter tunnel for the oil lines. The heater tube holes and inner longs will have additional plate added as we have discussed in the past, but inside the long, then a new outer rocker will be re-installed. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:05 PM |
