How much will it cost?, A price quote from Brad |
r_towle |
Oct 7 2003, 07:16 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Brad,
I will deliver you a chassis all modified, ready to go with an original six engine mount, cage and rough body work complete. I want you to find, install, tweek, road test, and finish the following 3.6 motor /6 G50 tranny with limited slip bigger axles and CV joints (you spec) cable shifter Engine management (original kit for the 3.6) Front mount oil cooler (I will leave the size up to you, basically I will cut the front bumper and add the lower GT valance) What else?? Body and interior I will take care of as well as the cage, though I could be convinced to let Tony do it while its there, otherwise I may stick with Chris because he is close enough for me to go down there, and I want to do a few un conventional things here. then I will come get it. So, no shipping for you, just find and install the basic list above. |
Brad Roberts |
Oct 8 2003, 08:52 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
There is not a 9146 header on the market that fits and has heat. I have this same problem on "Blackie" and plan to do a S-Car-Go "style" header with sheet metal on it for heat. With my time spent at SSI.. I learned quite a bit about how it should be done.. and B+B doesnt know their ass from a whole in the ground.
B |
Lo-Fi Version | Time is now: 27th September 2024 - 12:51 PM |
