EFI for my 73 2.0, Replacement fuel injection |
hotlanta914 |
Jul 15 2006, 07:47 AM
Newbie Group: Members Posts: 21 Joined: 15-July 06 From: Atlanta, GA Member No.: 6,438 |
(IMG:style_emoticons/default/confused24.gif) does anyone have a suggestion for replacing the stock mechanical fuel injection system with a modern EFI - don't want to go to carbs. Preference would be to end up with a complete, programable engine management system - including ignition - any suggestions?
ottox914 |
Jul 16 2006, 09:03 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I plan to look that over also, but the clearance SDS wants to the hall sensor is mighty tight, on the order of 2-3mm as I would recall, so the mounting of the sensor might be interesting, in terms of finding a small, flat area. The mounting on the pulley has several advantages, mostly being that the pulley and fan shroud can be moved easily from one long block to another, where as if the flywheel is worn below tolerances and needs re-surfacing, you'd need to re-mount the mags all over again on the replacement flywheel. Not the worst job in the world, but I'd rather do it once than twice. Also, I'm not sure which area would be "cleaner", such that there would be less possibility of oil/dirt/stuff getting on or fouling the sensor.
Any thoughts? |
Lo-Fi Version | Time is now: 26th September 2024 - 09:51 PM |
