WB O2 monitoring, Which one? |
lmcchesney |
Jul 21 2006, 08:26 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
A few questions regarding WB O2 monitoring.
When using the monitor to adjust you engine, is the data stored somewhere with cooralation with rpm/throtle position? Or is it just displayed and you have to record the associated data? Does the feed the information into the ECU like megasquirt, and the ECU adjust the A/F ratio for optimal operating? What setup has been found to be reliable and afforable? Thanks again, Larry |
lapuwali |
Jul 21 2006, 08:57 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Depends on the ECU and WB02 setup you choose. Megasquirt will (with a laptop) log EVERYTHING, and you can display graphs correlating everything together, including what the WB02 sensor reports. SDS will log a limited number of things, but there's no laptop, so you look at the numbers on the handheld thingie they provide.
The Innovate Motorsports LC-1 WB02 system is a favorite with the MS crowd. Well supported by MS, and it's $200. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:24 AM |
