Performance Coatings, Where to have it done??? |
Britain Smith |
Oct 15 2003, 09:22 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am wanting to have the 2.0L heads on my turbo motor coated with a thermal barrier. Does anyone have any suggestions on where to have this done and how much it should/will cost? Better yet, does anyone have a shop that does this?
-Britain |
RON S. |
Oct 16 2003, 07:16 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Britain,
Try calling a company called PolyDyn performance coatings.They are out in Houston I think.Web site is www.polydyn.com I used them back in the early '90s while doing some weekend mini-stock racing.They did many internal engine parts for me,of various types.An example on a piston.Thermal barrier on top,wear coating on skirts,and a teflon coating underneath the piston only came to about $10.00 per piston.We also did an oil absorbant coating on all the rod&main brg's.You'll have to adjust for proper clearances or you'll sieze a crank like we did the first time we toyed with coatings.Once we sorted that issue out and started over,I will say our engine did run 5-10 degrees cooler with the coatings while we raced it. They'll send you free info. Ron |
Lo-Fi Version | Time is now: 27th September 2024 - 04:17 PM |
