can/does a fuel pump, pump air?, bear with me.... |
type47 |
Aug 25 2006, 05:51 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
if you started with an empty fuel tank and hooked up all the hoses and lines for a D-jet fuel pump in stock position under the battery and then you put gas in the tank.... (finally getting to the point)... wouldn't you trap some air in the fuel line between the tank and the pump? if you run the pump, as in trying to start the car, would the pump eventually pump the air out and start pumping gas?
i think i might put gas in the tank and open the fuel line at the filter to get the air out. |
TravisNeff |
Aug 25 2006, 05:55 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
It will pump air, air is a fluid as well.
I have never had a problem with putting in a fuel pump - and have to prime it with fuel. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:11 PM |
