schematic component/actual physical location question |
type47 |
Aug 26 2006, 07:35 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
on page 128 in the Haynes manual, Figure 9.21, there is a pic of the relay board with fuses numbered 9 and 10. 9 is a 15 amp fuse, 10 is a 30 amp. does anyone know which fuse, 9 or 10, corresponds to the fuse S13 in track 93 on the schematic on page 181? the schematic is for a 74 model.
the page numbers for different printings may be different from the ones in the question above but the figure 9.21 probably is the same figure (maybe different page number) and the 74 schematic probably is the same schematic another way to answer this question is to figure if the fuel pump would use a 15 or 30 amp fuse. thanks! |
Dave_Darling |
Aug 26 2006, 09:15 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
None of them do. S9 would be the fuse corresponding to fuse #9. S13 is, I believe, one of the fuses on the relay board. Check the relay board diagram (also in Haynes) and look for which wire colors connect to the fuse; check the two diagrams against each other to see if the fuse in question is the front one or the back one.
--DD |
Lo-Fi Version | Time is now: 27th September 2024 - 06:52 AM |
