New Swaybar install Front and Rear, Decided I would document my sway bar installs |
914forme |
Sep 7 2006, 06:41 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Well I have bit the bullet sold the fron Weltmeister 22mm bar, and picked up a Nascar Hand me down.
As of today all the parts are in except the bearings, I will have them tomorrow, TSC (Tractor Supply Company) has the parts I need. I liked smart racings graphs so much I had to make my own. (IMG:style_emoticons/default/biggrin.gif) Foot Pound numbers are the upper column, size is across the bottom. With the arms I am running these are the rates I can achieve. Mr. H. Ross Perot, would be proud of me. Attached image(s) |
914forme |
Sep 16 2006, 06:32 PM
Well there is a picture in which hours of work went on.
Stripped the paint, test fitted, stripped some more paint, paint the inner fender with a zinc epoxy, and the back side of my re-infrocement plate. The welds will splatter a little more, but hopefully the zinc will make rust creep a thing of the past. Only time will tell. Here it is ready for wellding. I grab the welder, open the tank, lay down a few beads on a sub srtap plate I was makeing, and sfffff _______ what, yep no gas. And dang it, its past noon. So I went on and preped a bunch more stuff. I well now get it all test fit and ready to weld then have a welding marathon. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:11 AM |
