New Swaybar install Front and Rear, Decided I would document my sway bar installs |
914forme |
Sep 7 2006, 06:41 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Well I have bit the bullet sold the fron Weltmeister 22mm bar, and picked up a Nascar Hand me down.
As of today all the parts are in except the bearings, I will have them tomorrow, TSC (Tractor Supply Company) has the parts I need. I liked smart racings graphs so much I had to make my own. (IMG:style_emoticons/default/biggrin.gif) Foot Pound numbers are the upper column, size is across the bottom. With the arms I am running these are the rates I can achieve. Mr. H. Ross Perot, would be proud of me. Attached image(s) |
914forme |
Sep 24 2006, 05:56 PM
Thanks Trekkor.
Well got a little time this afternoon, after everything else wound down. Ground down and filled Pass side running light. Seam sealed the back side of my welds, and seam sealed the re-inforcement plates. The re-inforcements for the drivers side where primed in zinc. As was the inner fender well on the driver side. I made filler plates for the drivers side running lights, and the antenna hole. Pictures to follow. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:03 AM |
