914/4 calliper verses Volvo 4-pot caliper, picture and weights.......... |
Mueller |
Oct 29 2003, 04:20 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Timo had asked about the weight of the 4 piston caliper for the 200 series Volvos (offered for both solid and vented rotors)
Not as much of a difference as one would think (IMG:style_emoticons/default/smile.gif) Attached image(s) |
1973914 |
Oct 31 2003, 03:59 PM
Member Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 |
are you able to use a larger rotor? Bigger pads are fine if you are using them once or twice, but repeated heavy use at speed will simply overheat the smaller rotors. There is a reason the larger calipers/pads have larger rotors and/or more exocitc materials (carbon)....
Lo-Fi Version | Time is now: 27th September 2024 - 05:29 PM |
