Fuel pump, Is it dead? |
VINCE |
Nov 29 2006, 07:40 PM
VINCE Group: Members Posts: 19 Joined: 21-November 06 From: Auburn Hills, MI Member No.: 7,245 |
I was working on my FI 30 minutes ago. It is a L-jetronic (1.8L from 75).
I have changed some fuel hoses few days ago. My engine didn't not run because I had no fuel in fuel hoses!! So I tried to localise the problem: I ran the pump by pressing on the AFM flap. The pump worked 10 seconds and died. Now, when I press the AFM, I can hear 2 'clacs': - 1 from the relay (close to the battery) => OK - 1 from the fuel pump but the pump does not run Is my pump dead? What should I do? It is my daily driver: I need a solution, please help me. Thanks |
tradisrad |
Nov 29 2006, 09:13 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I'm not familiar with the L jet but I would first check voltage at the pump. With the d-jet, the pump can be run by jumpering across the relay and voltage then can easily be checked. 2nd, make sure that fuel is getting to the pump- blockages in the filter, tank, lines? The d-jet pump is very reliable, does the l-jet use the same pump?
good luck |
VINCE |
Nov 29 2006, 10:42 PM
Finally, I found that my fuel pump is OK. In fact, I inversed + and - and it started again. (IMG:style_emoticons/default/biggrin.gif)
I also fond what was wrong on my FI: my fuel regulator does not permit fuel to flow (IMG:style_emoticons/default/sad.gif) I have pressure at the inlet but not not at the exit. So I temporarply made a by-pass of the fuel regulator. The fact that my fuel regulator does not permit fuel to flow is a little strange because it seems to be new (see picture). My question is: Are fuel inlet and fuel exit correctly connected to me fuel regulator? See the picture enclosed (that was the way my fuel regulator was connected to fuel hoses). Thanks Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:02 AM |
