Installing a new (to me) engine., Steps and costs? |
KaptKaos |
Jan 14 2007, 01:15 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I posted this on Narp during the "Great Divide." I am now getting ready to start this project so I figured I'd post here, with the additional suggestions from the folks on Narp.
I picked up a 1911 motor from Grimstead a few weeks ago. I will be replacing my stock 1.7 with the 1911. I also have a set of 44 idfs for that motor too. So while I am going to swap this motor, I figured I'd check to see what else I should do "while I am in there?" If anyone knows the ball park costs for some of these items, please list it too, as it will help me budget. I don't want Dirk Wright disease, but I want to take care of any maintenance items while I have the old motor out and am prepping for the new one. clutch fuel lines tranny mounts new fuel pump - CB Rotary $60 various jets, and venturis for tuning the carbs - based upon recommendations (32 chokes) cv gaskets red loctite (something I need to get for all of this) trans mainshaft seal and cup bushing in the TOB arm... new bolts for the flywheel if you have it off A type 1 oil pump that has already had the shaft milled is a great investment if you want to upgrade your oil system & seals. Check the CV joints and repack them. Rebuilt alternator (I have a new starter) Check that right rear suspension point where the trailing arm pivots. Thats below the battery tray and corrodes from the inside out. $?? do andy's jumper wire at the engine relay board to power the pump. Help me out fellas! Thanks, Joe |
bperry |
Jan 14 2007, 04:24 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Quite a list of parts.
Do you have manifolds & linkage for the Carbs? Have you looked in the carbs to see what jets and venturi sizes you already have? Maybe you've looked already and know you need them but if not, I wouldn't necessarily replace all the seals/gaskets you have listed unless there were signs of leaking. As long as you are getting a fuel pump from CB performance ($54), I'd go ahead and get the jets, and chokes/venturi from them as well. They seem to have the best pricing when I've looked. 32mm chokes. ~$9/each Idle/Main jets ~$4/each. Also, from CB if you don't have it, get their "Weber Technical Manual". Best $10 you'll ever spend. You should be able to find prices pretty easily from the sources listed below. A few items I've priced recently Motor mounts are around $15-$20 each OEM transmission mounts are around $90 each. (there are some other non stock alternatives) Oil cooler seals ~$1-2 CV gaskets ~$2-3 copper exhaust nuts ~$1 each Alternator belt ~$10 Here are some places I've used that you can look for parts/prices: cperformance.com (Carb parts) Seem to have best prices on Weber parts and accessories. www.aircooled.net (Carb parts) These guys are a bit higher than CB but have returns on venturis. They also have some great technical papers on their site. pelicanparts.com (everything) www.autoatlanta.com (everything) allzim.com (everything) Call 800#, webpages aren't very good or complete www.gprparts.com/ (everything) Webpages are good but they have even more stuff if you call 800# ----------------------------- Defintely use the existing wiring for the power on the fuel pump rather than tapping off the coil. If you jumper pin III of the four pin connector on the relay board to gound, the original fump wires will be energized while the ignition is on. --- bill |
Lo-Fi Version | Time is now: 27th September 2024 - 08:58 AM |
