Not my brightest question! I am wearing my, dunce hat on this one, go easy!! |
army dude |
Jan 22 2007, 07:39 AM
The answer is 42 Group: Members Posts: 218 Joined: 12-December 05 From: Sarasota, Fl Member No.: 5,265 |
On my 74 teener with a v8 the "shift linkage bar/rod" has been cut,welded and worm clamped together and looks generally like crud!! I worry about its structural integrity. My question is.............Are there different "rods" for different years for side shift trannys? I need this before I post in the classifieds for one so I don't look silly on many boards. THANX!!!!! Ian in Iraq...Again |
rick 918-S |
Jan 22 2007, 08:43 AM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
When I did my shift rod I had two rods. I figured out how much I needed to lengthen the new rod. I cut both rods, one with the added length. Then I located a piece of round bar that fit inside and plug welded it inside one half, then slid the other section on and drilled a hole through it. I used a grade 8 bolt with a nylock nut to secure the other section. This allows me to remove the shift rod easier.
Lo-Fi Version | Time is now: 27th September 2024 - 12:21 PM |
