Installing a new (to me) engine., Steps and costs? |
KaptKaos |
Jan 14 2007, 01:15 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I posted this on Narp during the "Great Divide." I am now getting ready to start this project so I figured I'd post here, with the additional suggestions from the folks on Narp.
I picked up a 1911 motor from Grimstead a few weeks ago. I will be replacing my stock 1.7 with the 1911. I also have a set of 44 idfs for that motor too. So while I am going to swap this motor, I figured I'd check to see what else I should do "while I am in there?" If anyone knows the ball park costs for some of these items, please list it too, as it will help me budget. I don't want Dirk Wright disease, but I want to take care of any maintenance items while I have the old motor out and am prepping for the new one. clutch fuel lines tranny mounts new fuel pump - CB Rotary $60 various jets, and venturis for tuning the carbs - based upon recommendations (32 chokes) cv gaskets red loctite (something I need to get for all of this) trans mainshaft seal and cup bushing in the TOB arm... new bolts for the flywheel if you have it off A type 1 oil pump that has already had the shaft milled is a great investment if you want to upgrade your oil system & seals. Check the CV joints and repack them. Rebuilt alternator (I have a new starter) Check that right rear suspension point where the trailing arm pivots. Thats below the battery tray and corrodes from the inside out. $?? do andy's jumper wire at the engine relay board to power the pump. Help me out fellas! Thanks, Joe |
Grimstead |
Jan 25 2007, 09:31 AM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
You don't need to do it before the install but if you add a CHT gauge (and you should), doing the wiring at the same time you put the tin back on will make your life easier down the road...
Also, check the clutch, I'm 85% sure it's in really good shape but it's better to check now. AlsoX2, While the oil is still fresh, I didn't change it after I pressure washed the engine. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:03 AM |
