Superlite 15x7 25+ offset 4 lug 4x130 wheels, for those of you looking for something different |
Gint |
Mar 26 2007, 07:32 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I had half a dozen titles for this thread in my head... It's finally time to mount the Superlite wheels I bought in June 06. Mike Z was given a second chance offer from ebay when the auction didn't make reserve. He offered them up and I grabbed it. I bought them significantly cheaper than Pack Racing currently offers them for on their website. So it was worth it. Here's the original thread There were many questions (and even a little mis-information) in that thread. I'll answer quite a few here since I now have the wheels have tires mounted on them and I'm about to use them. BTW - 914world member Nick Mironov has a thread about his Superlite wheels. Nick's superlite wheel thread . Nick, you want to read this thread and possibly talk to Pack Racing about a set of inserts with a proper conical lug bolt/nut seat. This post has been edited by Gint: Jan 2 2013, 06:26 PM |
Aaron Cox |
Mar 26 2007, 08:50 PM
let me interject a little. offset is a pretty useless number, as it varies by width....
Backspacing is constant. backspacing is from the inner lip of the wheel to the mounting face. on a 914, you want between 112-120mm backspacing. every fuch wheel has almost the same backspacing even though the width changes. pretty cool. so if you know the max back spacing you can run on your car (before wheel hits inner fender well) You can then pick a custom wheel to fit your car in ANY width you would like. just easier to calculate IMO, those look so sick on your car gint! |
Gint |
Mar 26 2007, 08:58 PM
let me interject a little. offset is a pretty useless number, as it varies by width.... Backspacing is constant. backspacing is from the inner lip of the wheel to the mounting face. on a 914, you want between 112-120mm backspacing. every fuch wheel has almost the same backspacing even though the width changes. pretty cool. so if you know the max back spacing you can run on your car (before wheel hits inner fender well) You can then pick a custom wheel to fit your car in ANY width you would like. just easier to calculate IMO, those look so sick on your car gint! Actually, I disagree. Offset in it's simplest form is the distance from the wheel's centerline to the hub mating surface regardless of the wheel's width. And I like to have all of the numbers. I have no issue with calculating the offset in order to know what I'm dealing with. But that's just me... Details: Factory 5.5" 4x130 Fuchs wheel
I cheesed the Fuchs measurements. They have been corrected 3/28/07. Factory 4 lug (4x130 bolt pattern) Fuchs wheel has an positive offset of 39.6mm. Good information about wheel backspace and offset from Yokohama's web site QUOTE High Performance Wheels The following are various high performance wheel measurements that play an important role in determining tire and wheel fitment: Wheel Backspace This is the distance from the back edge of the wheel to the hub mounting surface. To determine the wheel backspace: 1. Position the wheel face down. 2. Lay a straight-edge across the back of the wheel. Measure the distance from the straight-edge to the wheel's hub mounting surface. Wheel Offset The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. The offset of a wheel can be one of three settings: * Zero offset: The hub mounting surface is even with the centerline of the wheel. * Positive offset: The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars. * Negative offset: The hub mounting surface is toward the back or brake side of the wheel's centerline. "Deep dish" wheels are typically negative offset. Offset can be calculated by positioning the wheel on a flat surface and measuring its overall width and backspace as shown below. Divide the overall width by two, then subtract this result from the backspace value. Offset = Backspace - (Rim Width รท 2) Here's a drawing from Fikse that I especially like. QUOTE This post has been edited by Gint: Mar 28 2007, 10:57 PM |
Lo-Fi Version | Time is now: 27th September 2024 - 05:35 PM |
