Superlite 15x7 25+ offset 4 lug 4x130 wheels, for those of you looking for something different |
Gint |
Mar 26 2007, 07:32 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I had half a dozen titles for this thread in my head... It's finally time to mount the Superlite wheels I bought in June 06. Mike Z was given a second chance offer from ebay when the auction didn't make reserve. He offered them up and I grabbed it. I bought them significantly cheaper than Pack Racing currently offers them for on their website. So it was worth it. Here's the original thread There were many questions (and even a little mis-information) in that thread. I'll answer quite a few here since I now have the wheels have tires mounted on them and I'm about to use them. BTW - 914world member Nick Mironov has a thread about his Superlite wheels. Nick's superlite wheel thread . Nick, you want to read this thread and possibly talk to Pack Racing about a set of inserts with a proper conical lug bolt/nut seat. This post has been edited by Gint: Jan 2 2013, 06:26 PM |
Gint |
Mar 28 2007, 11:39 AM
Mine are 15x7 25mm+ offset.
IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page |
sk8kat1 |
Mar 28 2007, 11:57 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
Mine are 15x7 25mm+ offset. IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page ...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along |
Aaron Cox |
Mar 28 2007, 12:30 PM
Mine are 15x7 25mm+ offset. IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset. Pack Racing Superlite page ...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... |
Gint |
Mar 28 2007, 12:36 PM
...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... (IMG:style_emoticons/default/blink.gif) They aren't *that* custom Aaron. They only have a few sizes and they don't offer a 15" in 30 or 35 offset. |
Aaron Cox |
Mar 28 2007, 12:40 PM
...so those 15" opions I would be able to direct swap my current 195/50/15's? what tire size would be needed for the 16x7 to get them to fit ..... I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups ... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along if you are ordering custom wheels... why use a spacer? get em to fit without a spacer! fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward... (IMG:style_emoticons/default/blink.gif) They aren't *that* custom Aaron. They only have a few sizes and they don't offer a 15" in 30 or 35 offset. preaching to the choir.... i KNOW that. did you require a spacer? nope. use a 23mm or your 25mm if thats all they make it in. im advocating doing the homework and research (find out what your camber is and how far inboard you can go to dictate offset and backspacing...) |
Lo-Fi Version | Time is now: 27th September 2024 - 05:35 PM |
