Installing Front Swaybar, Do I weld in the inner brackets or not?? |
rhcb914 |
Apr 7 2007, 10:34 AM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
So I have drilled the holes and cut the slot but I don't see any reference to welding in the brackets in the pelican tech article. Should I weld them in or just tighten the bolts and not worry?
-Rob |
hwgunner |
Apr 7 2007, 10:52 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
I actually spoke to some one who makes these nut plates and he did not recomend welding them in unless you know what you are doing. His concern was that a poor welding job would result in very thin sheetmetal at the edges which would be weaker than just bolting them in. Makes sense to me.
orange914 |
Apr 7 2007, 11:01 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
I actually spoke to some one who makes these nut plates and he did not recomend welding them in unless you know what you are doing. His concern was that a poor welding job would result in very thin sheetmetal at the edges which would be weaker than just bolting them in. Makes sense to me. eek! i have the tank out to do fuel lines/f.p. relocate AND was planing to install stock bar. i hadnt heard of the need to weld before. was the factory installed welded? i agree w/ dave darling if not welded by experianced welder it could compramise the sheet metal anyway. maybe spot welding the bolt heads to the inner plate would be a good idea as you could r&r bushings from inner fenders later (IMG:style_emoticons/default/driving.gif) . |
Lo-Fi Version | Time is now: 27th September 2024 - 10:20 AM |
