Head temps, HOT, difference between 1 and 3 |
yarin |
Apr 15 2007, 07:46 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I've got two of the VDO spark plug type head temp sensors. One on cyl 1 and one on cyl 3. I know that cyl 3 is the hottest, but i'm seeing differences of ballpark 30-40 degrees between the two. From the drivers seat I can't accurately read the gauges, so i'm going to move the gauges somewhere else and see how hot the temps get.
On the track the #1 cyl gets to about 365F. The #3 gets hot, unconfortably hot for me. I thinking around 400. I tried retarding timing 5-6 degrees total, didn't seem to make a difference. A little history: the PO was doing a hill climb and literally melted the right side of the engine (cyl 3 side). He had the head rebuilt and slapped it back together. Before I converted to megasquirt the carbs had all this metal crap (aluminum maybe) welded to the inside of the butterfly valves. I'm thinking this head really had a melt down. #3 always run hotter than #1, even at idle. I'm going check reading on my stock injection head temp sensor and see what Megasquirt says. It was bugging the shit out of me at the track. I kept looking over instead of concentrating on the course. Thanks Attached image(s) |
Jake Raby |
Apr 15 2007, 06:50 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The stock system is not bad, WHEN IT IS SET UP PROPERLY. These days few people understand the proper way it all goes together.
The other big issue is keeping the cooling fan clean, dirty fans can elevate temps by 30-50F easily. Modifying the cooling system to work better than factory is NOT an easy task. Generally any attempt to do this without extensive means of monitoring changes will result in negative results and I have certainly had my share of those. The key is not generating heat, thats the easiest way to make the stock system more effective! I have been working on some mods for the stock cooling system, primarily for VW Bus owners as there are more of those on the road than 914s and they have 4,500 pounds to push around (they also open their wallets for things that work) but the mods are the same for the 914 engine. Honestly an engine should not run hot, even in extreme climates if it is configured correctly and in tune. The stock engine is the hottest running of all- |
Lo-Fi Version | Time is now: 26th September 2024 - 08:08 PM |
