Head temps, HOT, difference between 1 and 3 |
yarin |
Apr 15 2007, 07:46 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I've got two of the VDO spark plug type head temp sensors. One on cyl 1 and one on cyl 3. I know that cyl 3 is the hottest, but i'm seeing differences of ballpark 30-40 degrees between the two. From the drivers seat I can't accurately read the gauges, so i'm going to move the gauges somewhere else and see how hot the temps get.
On the track the #1 cyl gets to about 365F. The #3 gets hot, unconfortably hot for me. I thinking around 400. I tried retarding timing 5-6 degrees total, didn't seem to make a difference. A little history: the PO was doing a hill climb and literally melted the right side of the engine (cyl 3 side). He had the head rebuilt and slapped it back together. Before I converted to megasquirt the carbs had all this metal crap (aluminum maybe) welded to the inside of the butterfly valves. I'm thinking this head really had a melt down. #3 always run hotter than #1, even at idle. I'm going check reading on my stock injection head temp sensor and see what Megasquirt says. It was bugging the shit out of me at the track. I kept looking over instead of concentrating on the course. Thanks Attached image(s) |
Twystd1 |
Apr 15 2007, 08:17 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Then there is the question of accuracy of the VDO gauges themselves.
C |
yarin |
Apr 15 2007, 10:32 PM
QUOTE 'Then there is the question of accuracy of the VDO gauges themselves. C Exactly... both visual resolution and accuracy. One tick = 50 degrees. Kind of hard to tell if i'm safe or melting away.. I've seen a few people post about the Dakota Series II Digital Head Temp System (link) Good bad? It's ambient temp compensated which is a huge advantage over the VDO. It also has a high temp alarm. Maximum temperature reading - 750°F (400°C) Gauge Resolution - 3-4°F (2-3°C) Gauge accuracy - ±10°F Anyone use this thing? Comments? (IMG:http://www.dakotadigital.com/cartimages/prd_sm_347.jpg) This is the cheapest price I could find.. |
Lo-Fi Version | Time is now: 26th September 2024 - 08:08 PM |
