A/C Power, Which pulley runs it? |
greybeard50 |
Apr 19 2007, 12:56 PM
Newbie Group: Members Posts: 46 Joined: 24-September 06 Member No.: 6,909 |
My 912e motor has two pulleys on the outer edge of the fan ~8" and a third (much smaller...3.5") that runs off a Rube Goldberg setup that bolts to the fan hub, brings the power out past the edge of the other two, has a bearing & holder arrangement then the pulley.
Only one is used to run the Alt. Which one runs the A/C? What is the third for? Finally, could the A/C be powered directly from the crank hub in the space behind the air chambers? TIA! |
Cap'n Krusty |
Apr 19 2007, 01:26 PM
The A/C pulley is behind the fan. You can't see it with the fan installed. Cars w/o A/C have a spacer instead of a pulley. The pulley on the extension bolted to the outside of the fan hub is for the air pump. The Cap'n
Lo-Fi Version | Time is now: 27th September 2024 - 01:59 PM |
