Rust Repair Help... Minnesota style., I think I'm ready to throw in the towel. |
914orRust |
May 3 2007, 11:33 AM
Newbie Group: Members Posts: 16 Joined: 20-August 05 From: St. Paul, MN Member No.: 4,623 |
Ok. About 2 years ago, I purchased a 74 teener. Since then I've had the engine rebuilt and replaced more parts than I dare list all the while knowing that there is some serious hell hole/rocker panel rust to address. The car isn't sagging yet but I know this is an issue that must be addressed.
To make matters worse... I live in Minnesota and I have no welding skills of my own. Thus far I've contacted a couple random body shops and I've received responses ranging from "no way I'm touching that" to "you need a top off restoration". I know I can't afford a top off restoration. So, my question to the list is... do I throw in the towel and sell to someone that has welding experience? Is there a solution that does not require a full restoration? Is that option available in Minnesota? Thank you in advance for any wisdom you may have with this issue. ~Marc |
Bartlett 914 |
May 6 2007, 09:17 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Brad Mayeur may also be a good option. He is in Peoria IL. It is a bit of a drive for you but may be worth it. He also has a long kit that is VERY strong. Your car will never sag with them. Your car is very fixable. I did see some rust on a fender. These areas should be looked after as well. Don't be shy. Show us all your rust. We won't be shocked. We have seen it all before.
Lo-Fi Version | Time is now: 27th September 2024 - 10:14 AM |
