Head temps, HOT, difference between 1 and 3 |
yarin |
Apr 15 2007, 07:46 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I've got two of the VDO spark plug type head temp sensors. One on cyl 1 and one on cyl 3. I know that cyl 3 is the hottest, but i'm seeing differences of ballpark 30-40 degrees between the two. From the drivers seat I can't accurately read the gauges, so i'm going to move the gauges somewhere else and see how hot the temps get.
On the track the #1 cyl gets to about 365F. The #3 gets hot, unconfortably hot for me. I thinking around 400. I tried retarding timing 5-6 degrees total, didn't seem to make a difference. A little history: the PO was doing a hill climb and literally melted the right side of the engine (cyl 3 side). He had the head rebuilt and slapped it back together. Before I converted to megasquirt the carbs had all this metal crap (aluminum maybe) welded to the inside of the butterfly valves. I'm thinking this head really had a melt down. #3 always run hotter than #1, even at idle. I'm going check reading on my stock injection head temp sensor and see what Megasquirt says. It was bugging the shit out of me at the track. I kept looking over instead of concentrating on the course. Thanks Attached image(s) |
yarin |
May 11 2007, 10:10 AM
I emailed tech support, got this response:
"If the sender doesn't fit around your spark plug, you can either drill it out so it will fit or you could cut the end and widen the loop." |
Lo-Fi Version | Time is now: 26th September 2024 - 08:08 PM |
