What the World needs now is... a progress thread, An update after 2 years? Unpossible! Yet, true. |
VaccaRabite |
May 21 2007, 09:18 AM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, when I started this restoration in October of 2005, I started a progress thread on the Subaru Board (NASIOC) that I active on. I have been meaning to create a thread here, but I never got around to it. I figured the kids over in ricer land would find it more amusing to see a classic resto in action then the folks here that have lived it.
But, I now post more here then I post in NASIOC OT, and feel more involved in the community then I did when I started. So, for the sake of ease, I am going to port over my posts from NASIOC, and posts from today on will be unique here. As I get ready to paint (JUNE 9th - 13th are PAINT DAYS!) this thread will get more active. :-) Zach PS, it kinda fun for me to do this. Looking over the old posts brings back memories of the ride... |
Zimms |
May 27 2007, 06:53 AM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
Zach,
Did you MIG weld the rotisserie yourself and if so, did you do much welding prior to welding it? I am going the same route, but need to pick up some welding skills. Thanks, Mark |
VaccaRabite |
May 27 2007, 10:39 AM
Zach, Did you MIG weld the rotisserie yourself and if so, did you do much welding prior to welding it? I am going the same route, but need to pick up some welding skills. Thanks, Mark Due to the thickness for the metal, I used flux cored wire at a high temp setting and a low wire speed. This was my first major welding project. I practiced a little, and had done a little sheet metal welding on my car. However, the thickess of the metal (1/8 inch wall thickness, 1/4 inch for a 2x2 that I got for free from a neighbor) anf CLEAN metal makes for very easy welding. Welding thick metal is way easier then welding thin metal. If you make good cuts (I used a power miter saw with a metal cutting blade) the welding goes together like a snap. I did not bother to grind down the welds. In fact, I made them a little thicker. Afte the first pass, I wire brush the seam, and then lay a second bead, really melting it in good. Probably not needed, but it made me feel better. On a lincoln 140 (or HD1400 - same welder, but sold via Home Depot) for 1/8 inch thick steel I was using temp D (the hottest) and wire speed between 2 and 3. For my welder, 1/8" steel is around the max that true MIG could weld, so I felt safer with flux core, which my welder is rated to 5/12 inch thickness. I have to admit, most of my freinds think it is more cool that I welded something from scratch that can supprt a car and is useful, then the fact that I am restoring a 30 year old car. Zach |
Zimms |
May 27 2007, 08:24 PM
Thanks for the info. I welded some thin sheet, and the results were nothing to write home about. I was getting fearful of welding something that would hold a lot of weight over me.
Lo-Fi Version | Time is now: 27th September 2024 - 05:51 AM |
