looking for euro or quality pistons for 1.7, information on the good and bad out there |
orange914 |
Jun 19 2007, 03:21 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
what new o.e.m. quality (raised compresion) piston/cylendars out there for my 1.7? what oversize can i go to (without heating problem or case/ head machining)?
Cap'n Krusty |
Jun 19 2007, 04:30 PM
Pelican's 90mm piston/cylinder sets are NOT OE. The Cap'n
orange914 |
Jun 19 2007, 07:15 PM
Pelican's 90mm piston/cylinder sets are NOT OE. The Cap'n i need to look up 1.7 spec's i assume 90mm is 2.0 bore? i'm still looking for answers on what the largest cylendar size is i can use with out machining to case/heads and are there heaing issues as the walls get thinner as i've seen with type I. i also hear stories about made in mexico pistons (IMG:style_emoticons/default/confused24.gif) i'm ready to buy pistons/heads and want the proper set up gaining as much reliable h.p. as realistic while doing this. |
Cap'n Krusty |
Jun 19 2007, 07:29 PM
Pelican's 90mm piston/cylinder sets are NOT OE. The Cap'n i need to look up 1.7 spec's i assume 90mm is 2.0 bore? i'm still looking for answers on what the largest cylendar size is i can use with out machining to case/heads and are there heaing issues as the walls get thinner as i've seen with type I. i also hear stories about made in mexico pistons (IMG:style_emoticons/default/confused24.gif) i'm ready to buy pistons/heads and want the proper set up gaining as much reliable h.p. as realistic while doing this. No, 90mm (as someone else just said) is 1.7 bore. 94mm is 2 litre (they also said that). 93mm is 1.8. The 93s and 94s drop in the case, but not into the heads. 94s have a different pin height, so you need the appropriate crankshaft and rods. If you're gonna buy heads, 1.7s are essentially unavailable, so you end up buying 1.8 or 2 liter heads. In that case, you need the appropriate pistons and cylinders. I have a set of K&S 1.7 914 pistons (higher compression than the T4 or Bus), but I want an arm and a leg for them. If you want to big bore, 96s seem to work OK, but larger sizes MAY have temperature issues. BEWARE that there are a lot of seriously substandard 94mm piston/cylinder sets out there. OE 93mm sets are NLA, too, AFIK. The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 12:21 PM |
