Need a little help.... Flywheel Bolts won't budge, Any tips?? bigger Braker Bar??? |
hwgunner |
Jun 18 2007, 11:42 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
OK, so I need a little help. For all the cars I have pulled apart, I am pretty much a maverick and just start pulling things off without reguard for order or proper form. I am trying to change that and pretty much hit a brick wall right off the bat. I can not get the flywheel bolts (17mm) to budge. I have not hit them with the impact wrench but have hit them with penetrating oil. Any good tips. I know these get torqued down to 120lbs or something but now how do I get them off. I want to get the flywheel off so that I can mount it on my engine stand with the steel 'ring' which brings up the second question. If you ae facing the trans end of the engine, which side does the ring go on so that you cansplit the case and get to all the good stuff in side. I know this is long but your help is appreciated. Here is a pic.
Attached thumbnail(s) |
Allan |
Jun 19 2007, 09:31 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
BTW, I said somthin' to the Cap'n about this and the grinder and he suggested cutting slots in the bolt heads and then using the impact screwdriver to get them off. No kiddin', he has an impact screwdriver you hit with a hammer. Unfortunately I have said things that didn't jive with what the Cap'n said and was wrong. I'm glad you got the flywheel off. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:55 AM |
