ANYONE know if 96mm cyl. walls are as thick as the oem, dont want overheating issues |
orange914 |
Jun 23 2007, 10:54 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
just as the title asks... im concerned with heat issues and thin walls
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/driving.gif) kenny thanks for the info, trying to figure this whole thing out (IMG:style_emoticons/default/thumb3d.gif) |
ptravnic |
Jun 24 2007, 02:14 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
the only advice I'm comfortable giving you re a rebuild is BE PATIENT. You will forget to account for something and have to wait a week or 2 or more for a part/parts. If you have a set time frame you will prob end up cutting corners or becoming very frustrated. Jake's video is a good start - BUT NOTE, he doesn't mention tapping the galley plugs in the video and apparently, it should be done...
-pt |
orange914 |
Jun 24 2007, 02:21 PM
the only advice I'm comfortable giving you re a rebuild is BE PATIENT. You will forget to account for something and have to wait a week or 2 or more for a part/parts. If you have a set time frame you will prob end up cutting corners or becoming very frustrated. Jake's video is a good start - BUT NOTE, he doesn't mention tapping the galley plugs in the video and apparently, it should be done... -pt are you talking about the oil galley plug that i've read about popping out? if so where is it located? |
ptravnic |
Jun 24 2007, 09:05 PM
the only advice I'm comfortable giving you re a rebuild is BE PATIENT. You will forget to account for something and have to wait a week or 2 or more for a part/parts. If you have a set time frame you will prob end up cutting corners or becoming very frustrated. Jake's video is a good start - BUT NOTE, he doesn't mention tapping the galley plugs in the video and apparently, it should be done... -pt are you talking about the oil galley plug that i've read about popping out? if so where is it located? yes, but there are 5 of them to drill, tap, & plug. Jake has a very helpful article on the what's & how's here: http://forums.aircooledtechnology.com/showthread.php?t=72 |
Lo-Fi Version | Time is now: 27th September 2024 - 03:26 PM |
