Air compressor question, Draining the water, but leaving it pressurized overnight |
VaccaRabite |
Jul 18 2007, 02:05 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a question about my air compressor.
Lately I have been turning it off when I am done working, then draining the water out via the drain plug. But once the water was out, I was leaving it pressurized for the next day. I figure that is less wear and tear then having to re-pressurize the tank every day that you need to do work, and would save time if you needed air for some other task (like charging a bike tire before going riding). if the tank was fully pressurized before I turn the compressor off, it could have ~100 psi of air after draining the water out of the bottom of the tank. Is this harmfull? I am taking the pressure out of the hose and setting my regulator for 0 PSI, so I don't think it would strain the regulator. Am I wrong here? Zach |
SLITS |
Jul 18 2007, 05:51 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The entrained moisture laden air kills your air tools. We used to drain once per week in the hot humid summer ... slightly less in the winter. Also, we did a daily injection of oil to protect the tools.
Now, we have a refrigeration system on the output to remove the moisture. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:20 PM |
