will a 225 pressure plate fit a 901 bellhousing? |
SirAndy |
Jul 24 2007, 10:03 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/blink.gif)
so i've been busy changing the clutch on my car, just got to the point where i was going to put the tranny back on and it's not sliding on. tried for half an hour, no luck. then i grab the box the new clutch and pressureplate came in and the box says: "KEP 915 225mm" will the 225 pressure plate for the 915 fit inside the 901 housing or am i F U C K E D ??? (IMG:style_emoticons/default/headbang.gif) i'm stranded at McMarks shop, i don't have a ride home and McMark is not here today. please tell me it ain't so ... (IMG:style_emoticons/default/unsure.gif) Andy |
Dr Evil |
Jul 24 2007, 10:47 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Are the splines the same? I am not sure off hand if the 915 and 911/901 trannies have the same splines. 225 is a fine size as far as that dimention.
John |
Jul 24 2007, 10:59 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Are the splines the same? I am not sure off hand if the 915 and 911/901 trannies have the same splines. 225 is a fine size as far as that dimention. The 915 alignment tool is larger in diameter than the 901 tool, so I don't think that is it. It almost sounds like the input shaft isn't wanting to slide into the pilot bearing....... |
Lo-Fi Version | Time is now: 27th September 2024 - 07:53 AM |
