will a 225 pressure plate fit a 901 bellhousing? |
SirAndy |
Jul 24 2007, 10:03 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/blink.gif)
so i've been busy changing the clutch on my car, just got to the point where i was going to put the tranny back on and it's not sliding on. tried for half an hour, no luck. then i grab the box the new clutch and pressureplate came in and the box says: "KEP 915 225mm" will the 225 pressure plate for the 915 fit inside the 901 housing or am i F U C K E D ??? (IMG:style_emoticons/default/headbang.gif) i'm stranded at McMarks shop, i don't have a ride home and McMark is not here today. please tell me it ain't so ... (IMG:style_emoticons/default/unsure.gif) Andy |
John |
Jul 24 2007, 10:26 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Did you use a centering tool for the disc when you tightened up the pressure plate? (I sure hope so)
Tried putting trans in gear and turning the output flanges to turn the input shaft? |
SirAndy |
Jul 24 2007, 11:36 PM
Did you use a centering tool for the disc when you tightened up the pressure plate? (I sure hope so) Tried putting trans in gear and turning the output flanges to turn the input shaft? yes and yes. used the tool, turned BOTH shafts about 50 times, used a flashlight to make sure the input shaft was actually turning ... got it in, took only another 30 minutes of brute force. (IMG:style_emoticons/default/blink.gif) i sure hope this is going to work ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Lo-Fi Version | Time is now: 27th September 2024 - 07:52 AM |
