throttle cable trouble, sleeve broken, stuck in tube... |
lotus_65 |
Aug 29 2007, 06:00 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
My throttle cable broke at the carb linkage so it needed to be replaced. No big deal, right?
Unfortunately the white plastic sleeve is broken at the firewall and WILL NOT BUDGE. Won't pull, won't push. I can (barely) get a needle nose on it, but it seems bound up inside the tube somewhere. I haven't pulled the cable out of the sleeve yet, as I had hoped to attach a string to help the new cable into place. I also dis-assembled the interior to get at the tunnel from the shifter, but there's no obvious advantage there. I ALMOST bought a sawzall to cut another access panel there, but came off that ledge... for now. What a PITA. (IMG:style_emoticons/default/headbang.gif) Anyone? paul |
Cap'n Krusty |
Aug 29 2007, 06:59 PM
First of all, using the old cable to pull a new one through is gonna be more trouble than just pushing the new one through the tube. It can only go in the right place, so the other cable is redundant. As you've noticed, the tube is just barely big enough to allow the end of the cable to pass through, and in many cases you have to sand/grind the swedge to make it fit. You're gonna have to pull the cable and the sleeve together, and pray that the end of the cable doesn't bunch up the sleeve and REALLY plug it up. I've used a VW bus solid wire heater cable and a drill to ream the tube, first just getting the wire through, then adding a little tiny bend at the end to cut through the plastic. It can take hours!
The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 08:07 AM |
