wisa' my car a runnin after i'a turn it offa', dieseling? |
pete914 |
Sep 17 2007, 07:01 PM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
so,
i'm running a carb on my engine and just recently i've noticed that after turning off the ignition it will turn over a time or two; kind of "rumble" to a stop. i've also noticed that my idle is kind of high, but not always. sometimes it idles around 900...usually it's at 1200...and recently it's been getting "stuck" around 1500 could this have anything to do with the electric choke? i was told to depress the gas pedal once before starting it to activate it. i checked the accelerator cable, no hang ups or anything. here's a pic of the carb. i know it's a POS, but the car is running great, it's just the idle and the every-so-often cut off weirdness that's bothering me. (IMG:http://i35.photobucket.com/albums/d189/pba110/914/IMG_1553.jpg) nonetheless, i'm considering putting a d-tronic on my 1.8...i have the FI in my garage...but should i just wait and get the proper l-tronic system? that would be another $250 out of my pocket....worth it in the long run? can't decide!!!! (IMG:style_emoticons/default/idea.gif) thank you for your input gentleman pete |
SLITS |
Sep 17 2007, 07:30 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It's a really old (like me) trick. Water makes steam and may knock the buildup off. I said slowly 'cause you can crack a piston, etc if you pour it fast.
Many moons ago water injection was used to boost horsepower for passing (look up Hudson Hornet). |
Lo-Fi Version | Time is now: 27th September 2024 - 03:20 PM |
