VW Badge location & body numbers, Challenge to determine beginning & end |
davep |
Sep 23 2007, 06:23 PM
914 Historian Group: Benefactors Posts: 5,212 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I require help with my research.
Typically, the VW badge was riveted to the right headlight bucket up to the end of 1974 and made its way to the right upper corner of the fuel tank bulkhead in 1975. Also, the body number was originally stamped into the rear trunk floor and made its was to a black riveted tag on the support below the right headlight bucket, as well as being found on the Karmann badge. At some point the body number base changed from xxy95zz to xxy90zz. I require everyone to help with changeover VIN, and body number for each of the changes. Please add paint code and date code from the compliance decal as well. Attached image(s) |
ClayPerrine |
Oct 4 2007, 09:33 PM
Life's been good to me so far..... Group: Admin Posts: 15,901 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Dave,
I got your note. Betty's vin is 4742917597. The build date on her car is 4/74. We don't have the door jamb sticker, we lost it in the fire. And I can't check the rear trunk, the panel was replaced when the body work was done. Here is the tag in the front trunk (sorry for the Andy style picts). And here is the body tag. Hope that helps narrow down your search. |
Lo-Fi Version | Time is now: 23rd November 2024 - 03:26 PM |
