What is the curent thinking on exhaust stud nuts, Copper or regular? |
thomasotten |
Oct 10 2007, 10:52 AM
Senior Member Group: Members Posts: 1,553 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Are the copper coated nuts the way to go, or is using regular bolts, double bolting the way. I read something yesterday that said the copper nuts should only be used once...why?? Should I coat the studs with anything?
brer |
Oct 10 2007, 04:22 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
its worth noting that SS nuts on stock studs is pretty much a waste.
they will rust along with the stud. if you use SS nuts then SS studs would also be a must. |
URY914 |
Oct 10 2007, 06:45 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,027 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
its worth noting that SS nuts on stock studs is pretty much a waste. they will rust along with the stud. if you use SS nuts then SS studs would also be a must. You're saying a SS nut will rust because it is on a SS stud? Really? They don't where I live. Please explain. |
Rand |
Oct 10 2007, 06:52 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
its worth noting that SS nuts on stock studs is pretty much a waste. they will rust along with the stud. if you use SS nuts then SS studs would also be a must. You're saying a SS nut will rust because it is on a SS stud? Really? They don't where I live. Please explain. Not what I thought Brer said. Are stock studs stainless? But I figure some Milk of Magnesia on the threads and double SS nuts is the way to go. The biggest trick is getting a hold of the top nut well enough to tighten the two nuts against each other enough to lock them. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:15 PM |
