Rear wing project COMPLETED with pics, I ran it for the first time Sunday |
URY914 |
Aug 15 2007, 08:41 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,026 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I can't leave well enough alone. It's 66" wide, 52" from the ground to the top. I cut some masonite supports which will be 1/8" aluminum, and used a piece of cardboard for an end plate. I haven't decided on end plate material, could be CF, FG, lexan, aluminum, whatever.
Attached thumbnail(s) |
URY914 |
Oct 11 2007, 07:40 AM
The wing itself was wrapped with several layers of fine f/g cloth and sanded smooth. I used "Cap-o-Sil" for the first time as a f/g filler. The stuff is like f/g powder that is added to your resin mix to thicken it up. You can add it until it is thick as cold 20/50 oil. It stays where you want it with out running down the surface of the piece. Gunnar Racing uses it a lot on thier projects.
The end plates will held on with socket head cap bolts thru the plate and into the end of the wing. I added threaded inserts into the wing ends than glued and glassed them in. The plywood end piecs are used to hold the wing while working on it. Attached image(s) |
Lo-Fi Version | Time is now: 26th September 2024 - 09:56 PM |
