2.0 throttle body mod's., what have you used with what issues |
orange914 |
Dec 13 2007, 03:20 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
just wondering what t.b. conversions are out there and what issues have been incured?.
what size is the stock t.b. anyway |
jd74914 |
Dec 13 2007, 06:09 PM
Its alive Group: Members Posts: 4,796 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Don't bore it out.
Think of it using this equation: m(dot)= p*A*V. (p is a constant, the density of air) The engine consumes a finite amount of air (M(dot)). This value is only dependent on engine speed. The air's speed is inversely dependent on the area of the TB/runners it flows through (A). When these have larger cross-sectional areas the air inside of them moves at a slower rate (V), which kills efficiency. Maximum power can be found with air speeds of around .4 or .5 mach usually. Once you go supersonic efficiency drops though. Basically you want high intake port air velocity for best performance. (IMG:style_emoticons/default/smile.gif) |
orange914 |
Dec 13 2007, 11:08 PM
Don't bore it out. Basically you want high intake port air velocity for best performance. (IMG:style_emoticons/default/smile.gif) The stock unit is adequate for 150HP and 2300ccs.... (IMG:style_emoticons/default/thumb3d.gif) sounds like any mods would defeat any gains for street 2056 d-jet |
Lo-Fi Version | Time is now: 27th September 2024 - 05:57 AM |
