Fixing poor leakdown, Cyl 1 leaks at 50%, rest are cool. |
VaccaRabite |
Oct 24 2007, 07:00 AM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, at the Sterling meet I did a leakdown test on my motor, and found a problem with Cylinder 1. 45% leakdown, but 120 lbs of compression. Was tempted just to let sleeping dogs lie, but pulled the head off.
What was going on was clear as soon as we did that, the head was not totaly sealed to the cylinder, off by a very small amount. Instead of having the head recut, I decided to try and lap the two of them together. So, last night I hand lapped them, using ground graphite to check for even contact. I got good contact after the third round of hand lapping (lap, clean, check). Now I need to get the jug back on the block. I have a ring compressor on the piston, but I can't ficgure out how to get the head back on. Do I have to take the piston head off the rod? If so, how do I get it off. It looks like that tis a spring keeper that needs to be removed. Is there anyhting on the rod the needs to be loosened before I can pull the pin out to remove the piston head? Obviously, if there is a trick to getting the jug back on without pulling off the piston head, I'd like to do that. Zach |
davep |
Jan 2 2008, 03:27 PM
914 Historian Group: Benefactors Posts: 5,195 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Perhaps Jake will chime in on this for the definitive answer. He uses very specific piston to cylinder clearances that depend on the specific cylinder and specific piston.
For boring out the cylinder I understand that the cylinder MUST be clamped in a fixture just as it will be on the engine; that is, the cylinder will be clamped with equal force to what it sees between the case and head. Apparently there can be a small amount of warping of the cylinder when it is clamped as opposed to when it is sitting free. Thus the cylinder must be clamped when it is bored so that it remains perfectly cylindrical when it is installed on the engine. |
Lo-Fi Version | Time is now: 27th September 2024 - 07:52 AM |
