Need front end alignment #s, does anyone have the stock toe camber caster #s |
finstermojo |
Jan 12 2008, 03:47 PM
Newbie Group: Members Posts: 40 Joined: 10-November 07 From: new york Member No.: 8,314 |
I tried doing a search but it was to much to go through does anyone have the stock set up for the front and the rear tire alignment settings for the 914 This info would also be useful to list in with the 914 info up at the top of the site where vin # colors codes etc are listed. Thanks |
John |
Jan 12 2008, 04:20 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I tried doing a search but it was to much to go through does anyone have the stock set up for the front and the rear tire alignment settings for the 914 This info would also be useful to list in with the 914 info up at the top of the site where vin # colors codes etc are listed. Thanks Here is the alignment card that I use. I print out a new copy and make notes on it when I do alignments. I note where I started and where I end up and date them. Good luck. Attached File(s) 914_Alignment_Card.pdf ( 34.73k ) Number of downloads: 300 |
Lo-Fi Version | Time is now: 27th September 2024 - 06:53 AM |
