replacing brake rotors, do I need to replace bearings as well? |
VaccaRabite |
Feb 1 2008, 11:48 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As the title says. I am going to replace my brake rotors, as they are worn. Do I need to replace my wheel bearings as well? Is there a simple test to see if they are good to go as they are?
Zach |
SirAndy |
Feb 1 2008, 11:57 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
As the title says. I am going to replace my brake rotors, as they are worn. Do I need to replace my wheel bearings as well? Is there a simple test to see if they are good to go as they are? front or rear or both? if the bearings are still quiet, the shakedown test works fairly well. also, do the slow turn thing and listen for noise from the bearing ... the rotors can be replaced without changing the bearing. when was the last time you got new wheel bearings? if the answer is "dunno", now is probably a good time to replace them as well ... (IMG:style_emoticons/default/biggrin.gif) Andy |
Lo-Fi Version | Time is now: 27th September 2024 - 07:58 AM |
