replacing brake rotors, do I need to replace bearings as well? |
VaccaRabite |
Feb 1 2008, 11:48 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As the title says. I am going to replace my brake rotors, as they are worn. Do I need to replace my wheel bearings as well? Is there a simple test to see if they are good to go as they are?
Zach |
Dave_Darling |
Feb 2 2008, 12:49 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you have stock four-lug front rotors, they cannot reasonably be changed without changing the wheel bearings. The five-bolt stuff can, but on the four-bolt setup the rotor is a part of the hub.
--DD |
Cap'n Krusty |
Feb 2 2008, 09:13 AM
If you have stock four-lug front rotors, they cannot reasonably be changed without changing the wheel bearings. The five-bolt stuff can, but on the four-bolt setup the rotor is a part of the hub. --DD What? They're easily transferred from the old rotors to the new ones. That said, you'll need new seals whichever route you choose. Frankly, I'd replace them anyway. The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 07:54 AM |
