My 914-6 project, That's a rap, Thanks Everyone!!! |
sbsix |
Jul 12 2012, 09:42 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 454 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
wish this one turned out without the glare, but it shows the end curve of the oil line hook.
Hope this helped a bit. Keep up your restoration posts, they're fantastic and inspiring. Sorry for all the undercoating in the pictures, this car was delivered and driven in Germany for a few years and they covered the underside in this thick goop. I'm almost afraid to scrape it off for fear of the car falling apart! Attached thumbnail(s) |
Socalandy |
Jul 12 2012, 11:16 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Socalandy |
Jul 16 2012, 10:10 PM
Thanks Jeff and Eric (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/shades.gif)
Holy (IMG:style_emoticons/default/stromberg.gif) these are nice!!!!! Attached image(s) |
Socalandy |
Jul 16 2012, 10:12 PM
Socalandy |
Jul 17 2012, 10:45 PM
notches for body plugs cut and stop dimple hammered in, e-brake tunnel. Time for the seat mounts (IMG:style_emoticons/default/smash.gif)
Socalandy |
Jul 21 2012, 07:20 PM
more progress after a trip to see another 914. Yep, with Kent working on 914 #2 for me he has picked up this addiction (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/aktion035.gif) V8 Conversion 72 and I will make sure he adds it to the database.
Bottom edge of flares cleaned up and body plugs fit sweet. Attached image(s) |
Socalandy |
Jul 21 2012, 07:24 PM
Socalandy |
Jul 21 2012, 07:29 PM
flares are rock solid!! The dent in the bottom of the pass. side long was pulled out and back where it belongs
Socalandy |
Jul 25 2012, 09:18 PM
Carbs are finally done (IMG:style_emoticons/default/drooley.gif) Please ignore the manifolds, I'm resizing the clean set to the larger heads.
Socalandy |
Jul 25 2012, 09:29 PM
and picked up some powder coat this morning. Time to start putting the front suspension together And Kent made some progress at the shop with the engine mount (IMG:style_emoticons/default/aktion035.gif)
Socalandy |
Jul 26 2012, 06:49 PM
Looking for a confirmation on if this is the correct oil return line from the engine case so I cant have the rest of the lines made?? The bends don't seem quite right and ones a bit longer
Thanks Attached image(s) |
1TRICK6 |
Jul 27 2012, 09:09 AM
Newbie Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California |
Looking for a confirmation on if this is the correct oil return line from the engine case so I cant have the rest of the lines made?? The bends don't seem quite right and ones a bit longer Thanks Check this link http://forums.pelicanparts.com/porsche-914...ished-part.html Jim |
Socalandy |
Jul 27 2012, 10:52 AM
Thanks, I'd seen these and some others on the GT site and that's what started my question. You can see they are similar but have different lengths mainly up front where the nose cone mounts to the engine.
I wish there was a P/N on it (IMG:style_emoticons/default/wacko.gif) |
Socalandy |
Jul 31 2012, 10:10 PM
resizing the intakes to match the 3.0 heads. I'm happy with the bit I'm using, it will take less work getting the final finish I want to end up with.
Socalandy |
Aug 1 2012, 10:12 PM
did some mock up on the front oil cooler so cutting can begin and got the rear sway bar mounts on the car. Slowly chipping away at the list (IMG:style_emoticons/default/smash.gif)
Socalandy |
Aug 1 2012, 10:47 PM
rear deck lid is ready for final prep. Kent did a great job getting this back into perfect shape again!!!
Socalandy |
Aug 4 2012, 12:23 PM
Started the oil cooler install (IMG:style_emoticons/default/biggrin.gif)
Mr.242 |
Aug 5 2012, 09:00 AM
May your glass be smaller so it's always FULL! Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
Nice looking car and the work is top notch! Cannot wait to see this car done and driving.
Steve |
Aug 5 2012, 09:22 AM
914 Guru Group: Members Posts: 5,728 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Nice work Andy!! Thanks for sharing!!
ConeDodger |
Aug 5 2012, 10:21 AM
Apex killer! Group: Members Posts: 23,823 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Andy,
You have probably already seen this picture but I thought I would post this... This is what an 8.5X16 looks with 225.50X16 tires on AA flares. Your factory flares don't have the flange on the inner arch. Mark had to trim my flares to fit these. You should be just fine... Great build! (IMG:style_emoticons/default/first.gif) Attached image(s) |
Lo-Fi Version | Time is now: 23rd November 2024 - 12:44 PM |
