Engine Stand, T4 or 6 |
tracks914 |
Apr 19 2004, 03:58 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I made an engine stand hub for my T4 1.7. It worked like a charm. It has a nice fit on the transmission spigot.
My buddy is doing his 2.4 for his 911 and wants to borrow it. Is the flange the same on the two engines? Will it fit? Tx Doug |
tracks914 |
Apr 20 2004, 05:26 PM
Before this gets buried on page 4.....anyone? (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
Mark Henry |
Apr 20 2004, 05:34 PM
Your overkill stand should work fine.
Rusty |
Apr 21 2004, 02:37 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Let's see the one you made! -Rusty (IMG:style_emoticons/default/smoke.gif) |
Mark Henry |
Apr 21 2004, 05:16 AM
He posted a pic quite a while back. It was a homemade (work (IMG:style_emoticons/default/wink.gif) ) head that was total overkill, on a V8 stand.
If I remember correctly. (IMG:style_emoticons/default/cool.gif) |
Rusty |
Apr 21 2004, 06:51 AM
maxwelj |
Apr 21 2004, 07:32 AM
rebuilt member Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None |
I used a VW head from JC Whitney, thinking I would just modify the part that goes into the base, but it happened to fit as is. I did have to grind on the bolt flange a little to get it to clear the ridge on the block, however. It bolts to one of the case halves only. I'm not sure whether I could put the flywheel on, but it seems to hold my 6 OK. And for less than $50, I'm happy!
tracks914 |
Apr 21 2004, 02:08 PM
Here is a picture of it. I really just wanted to know if the flanges were the same size.
tracks914 |
Apr 21 2004, 02:09 PM
and another with it attached to the T4
tracks914 |
Apr 21 2004, 02:11 PM
And of course with the engine done and dressed. (just cause I like the look of it)
Mark Henry |
Apr 21 2004, 02:38 PM
You could mount the whole 911 on that! (IMG:style_emoticons/default/biggrin.gif)
Yes the bellhousing flange is the same. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:16 PM |
