Believe MPS is bad- now what?, Buy Rebuilt-Used |
sfrenck |
Feb 15 2011, 06:24 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Don't know what to tell you there - I (and a friend of mine) both got our MPSs from PH for $165 +core last summer (person I spoke to there was named Jeff).
Also, Automotion's website lists the MPS @ $197 + core.... (IMG:style_emoticons/default/confused24.gif) I would have listed my pricing earlier - but I don't know if it's proper on this site (Sorry Admins if this is the case). |
Bleyseng |
Feb 15 2011, 06:30 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Last I heard PH MPS rebuilds are all set to 1.7 calibrations, is this still true?
sfrenck |
Feb 15 2011, 06:45 AM
Last I heard PH MPS rebuilds are all set to 1.7 calibrations, is this still true? I was not told that... also, my PH MPS (and my friend's) was actually from Fuel Injection Corp (unless they put their MPS in an FIC box). I have no way to test the MPS, so I'll go happily along believing that mine is correctly calibrated - only based on the fact that they wanted more $$ for the '73 2.0 MPS than a '74 2.0 MPS. I contacted FIC via this board once (member FIC72)- I believe he offers a 914world "discount". |
brenz |
Feb 15 2011, 11:27 AM
Member Group: Members Posts: 56 Joined: 10-March 10 From: Delaware, USA Member No.: 11,451 Region Association: MidAtlantic Region |
Don't know what to tell you there - I (and a friend of mine) both got our MPSs from PH for $165 +core last summer (person I spoke to there was named Jeff). Also, Automotion's website lists the MPS @ $197 + core.... (IMG:style_emoticons/default/confused24.gif) I would have listed my pricing earlier - but I don't know if it's proper on this site (Sorry Admins if this is the case). For what it's worth I'm the friend Scott speaks of. I do remember seeing the MPS listed on Parts Heaven website as $530. I think that might have been for a new one. I called and also talked to Jeff and he quoted me $165 for a rebuilt '74 2.0. He only had one at the time. He said the rebuilder goes by manufacturer specs, but I don't know either what that means. My car is not 100% up and running so can't comment on the calibration. It's worth a call anyway. Bryan |
SLITS |
Feb 15 2011, 12:22 PM
Not sure what FIC does, in that they bought Brett Instruments who did all the MPS rebuilding at one time in the past.
Brett had diaphrams made of stamped steel. The flex characteristics were not the same a stock, but did work. At that time they had an NOS MPS (can't remember if it was a 1.7 or 2.0) and they were calibrated to it The second method of "rebuild" is to scarf a good diaphram from another unit that is good (no matter the number as long as the diaphram is configured the same). It's a crap shoot ...... Oh, the last time I heard, a new MPS (if still available) was $1600+ |
Bleyseng |
Feb 15 2011, 01:10 PM
yes, I have seen a bunch of stamped steel diaphrams and don't like the throttle response they have. Brett did use a copper diaphram for many years but it had less pleats than the OEM ones.
The best rebuild units is using a OEM diaphram in a good body and recalibrate it to the engine you have. Smoothest running by far! |
ConeDodger |
Feb 15 2011, 01:11 PM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If someone doesn't solve the diaphragm problem for the stock 1.7 - 2.0 MPS soon the only thing you will be able to do when you believe your MPS is bad is to find others who also believe your MPS is bad and start a church. At least then, you can write off your expenses...
tod914 |
Feb 15 2011, 09:09 PM
There was a topic sometime ago, that Bosch has a rebuild service for them. Not sure what their limitations are in regarding what's rebuildable and what is not.
914_teener |
Feb 16 2011, 09:31 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If someone doesn't solve the diaphragm problem for the stock 1.7 - 2.0 MPS soon the only thing you will be able to do when you believe your MPS is bad is to find others who also believe your MPS is bad and start a church. At least then, you can write off your expenses... (IMG:style_emoticons/default/laugh.gif) Ok...update. Looks like Parts Heaven and find a local calibration expert once the part lands back to me if I have response problems. Going to yank the injectors this weekend replace fuel line elbows and go through the top end while I wait for the MPS next week. Wish me luck. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:45 PM |
