69 Pages V « < 14 15 16 17 18 > »
> Just another damned project thread, 914-6 3.2 conversion in GT dress-up
ConeDodger
post Nov 20 2011, 12:06 AM
Post #301
Apex killer!
https://www.youtube.com/watch?v=6thmeRVz2So
Mike Bellis
post Nov 20 2011, 12:11 AM
Post #302
Resident Electrician
Why is the CHECK ENGINE light on? (IMG:style_emoticons/default/WTF.gif)
ConeDodger
post Nov 20 2011, 12:15 AM
Post #303
Apex killer!
Check Engine? We have to figure that out...
Here is Mark with his helmet on... Wait, that isn't a helmet is it? (IMG:style_emoticons/default/blink.gif)
rick 918-S
post Nov 20 2011, 08:11 AM
Post #304
Hey nice rack! -Celette
Nice! (IMG:style_emoticons/default/MDB2.gif)
DNHunt
post Nov 20 2011, 09:52 AM
Post #305
914 Wizard? No way. I got too much to learn.
I wonder if the check engine light is on because the coolant sensor (CHT) is out of range. The firmware may be set up to turn it on if the temp is above 210.
Dave
ConeDodger
post Nov 20 2011, 09:58 AM
Post #306
Apex killer!
QUOTE(DNHunt @ Nov 20 2011, 07:52 AM) *
Dave
That is a possibility. I noticed that although the A:F ratio was just slightly on the rich side of stoichiometric the temperatures were low. Oil temperature was low normal but CHT was a bit low. EGT was more 'reactive'. It only went up when I was hammering on it. Which was pretty much all the time. (IMG:style_emoticons/default/biggrin.gif)
Jake Raby
post Nov 20 2011, 11:41 AM
Post #307
Engine Surgeon
Looks like fun... The CEL can also illuninate if you have a sensor reading thats erratic, like the AIT sensor, CHT or MAP.
The idle sounds a little high, unless you were on the accelerator while staging... All that heavy decel and engine braking forces the rings to seat.. Looks pretty quick :-)
Imagine that same engine combo, but with a tad more CR in my 356..
ConeDodger
post Nov 20 2011, 04:00 PM
Post #308
Apex killer!
QUOTE(Jake Raby @ Nov 20 2011, 09:41 AM) *
We left the idle high on purpose for now. Mark will be dialing that down soon. I would guess the culprit to be MAP then. This thing is prettty potent without the added CR. I was at 38.411 for my fastest time. FTD was either a Stalker or a Super 7 at around 35.XX. Those are 1200# vehicles with 1/2 the HP or more... Pretty hard to beat that kind of weight to HP ratio and race tires. I was like a proud papa with McMark. He started the day in the 45 second range and dialed it down to 39.XX in steady .5 to 1 second improvements. He also knew enough not to beat me in my own car. That would be a borrowed car foul!!! (IMG:style_emoticons/default/mad.gif)
Once again, this engine will require a learning curve. I was going so fast at the end of the fast sections that I was busier than a two-peckered owl in mating season! I would either have to slow down or polish my skills up to keep going that fast... This will be a terrific track day engine for sure! I did not think that it was possible for my car to push as polished as the set up is. But I was going so fast into turns that she would push like a pig! Toward the end of the day, I had figured out how to set myself for the corner and throttle steer around the turns. Mark was driving much smoother than I was but he was also experiencing the push. I think he even looped it once but I was the course marshal so I had to flag people on to the course and couldn't pay him too much attention. Not quite sure what to do about the push. The weight of the engine hasn't changed appreciably so the corner balance can't be too far off. It was colder (and wetter in the morning) than a witches tittie so that is a bit of it. It started to warm up in my second set of six runs but we lost the sun again in the afternoon. Mark got the better part of the warm day for his runs but he was still on the steep part of the learning curve then. He dialed it down to 1 second behind me by the end of the day with a cold track. This tells me that he will eventually beat me with practice. So of course this means he will need to find a car to autocross (IMG:style_emoticons/default/mad.gif) I can't have him beating me in my own car! (IMG:style_emoticons/default/sad.gif)
McMark
post Nov 20 2011, 04:28 PM
Post #309
914 Freak!
Got one of my morning runs on YouTube now...
https://www.youtube.com/watch?v=Kt6Eeu9_w90
Oh, and I never looped it. I never hit a cone. (IMG:style_emoticons/default/tongue.gif) But that probably means I wasn't pushing it hard enough. So yeah, it's time to get my car finished up and get some AX action. I had a blast. Best time: 39.386. I really didn't think I had any more time to gain before I headed into the third session, but turned out that I pulled a second off my previous best time.
It was a great shakedown run for Rob's car. Now we know a few little things that popped up that can be sorted out and it's got enough time on it for another oil change and valve adjustment. Plus the necessary nut-n-bolt check to make sure everything is staying tight.
Okay, enough chit-chat. I'm gonna go hack Rob's car up. (IMG:style_emoticons/default/sawzall-smiley.gif)
(IMG:style_emoticons/default/happy11.gif)
Mike Bellis
post Nov 20 2011, 04:31 PM
Post #310
No check engine light on that run. (IMG:style_emoticons/default/biggrin.gif)
McMark
post Nov 20 2011, 04:32 PM
Post #311
914 Freak!
Yeah, I wasn't punching the throttle like Rob was. (IMG:style_emoticons/default/shades.gif)
ConeDodger
post Nov 20 2011, 05:21 PM
Post #312
Apex killer!
QUOTE(McMark @ Nov 20 2011, 02:28 PM) *
Ya'll notice the (IMG:style_emoticons/default/happy11.gif) and (IMG:style_emoticons/default/sawzall-smiley.gif) smileys? I couldn't stand to be there for this part... (IMG:style_emoticons/default/sad.gif) When you start with a car that has only 70XXX miles and was pretty original and well preserved, it's a little hard to watch it cut up for flares... Good thing I trust McMark right? (IMG:style_emoticons/default/biggrin.gif)
Jake Raby
post Nov 20 2011, 07:14 PM
Post #313
Engine Surgeon
It didn't sound like you ever really hit WOT.. Did you?
McMark
post Nov 20 2011, 07:15 PM
Post #314
914 Freak!
I might not have.
ConeDodger
post Nov 20 2011, 07:21 PM
Post #315
Apex killer!
QUOTE(Jake Raby @ Nov 20 2011, 05:14 PM) *
Not enough room Jake... But with all that torque you can see me jumping around sideways through that last section of sweeper... I think Mark had the secret. He wasn't as tempted to use it all and was able to use all of the finesse built into that suspension. I normally beat people who beat me yesterday so like often happens with your engines, I slowed down. Last event, I hardly touched the brakes. Pretty much only to transfer weight. This time I'm locking them up and pushing through corners like a plow... NEED MORE TIRE! (IMG:style_emoticons/default/blink.gif)
Note: With Jake's engines, you often slow down before you go faster due to the fact that all of that HP and torque takes a while to get used to... (IMG:style_emoticons/default/huh.gif)
JStroud
post Nov 21 2011, 01:12 AM
Post #316
QUOTE(kg6dxn @ Nov 20 2011, 02:31 PM) *
Maybe Mark had his seatbelt fastened and Rob didn't (IMG:style_emoticons/default/av-943.gif)
Sounds like you guys had a great day, new motor seems to be everything you wanted. Next year will be like having a whole new car!
Glad all went well.
Jeff
Randal
post Nov 21 2011, 09:56 AM
Post #317
Wow, sounds like you guys had a great day. Wait till you get some race tires under that puppy. OK now is the time for Mark to start on Phase II, getting some weight off...he knows where to start!
What you'll find is that it takes about a year to begin to manage the loud pedal. Actually all the torque is pretty mesmerizing; you'll be going down a straight and just blown away by how well the car moves. You end up thinking about THAT and boom, here comes a corner and back to reality.
Anyway was thinking about the Infineon event when I started the early morning Thanksgiving Day work orders issued by the wifey. Man, so much work, but was done in time to watch the 49'er on Sunday afternoon.
Start planning on coming up to Medford for the Spring Enduro. I'm going for sure and will be saving a good pair of Canti's for the event. You can wear out a set of tires as they practice Friday and Saturday, then run Sunday, i.e. tons of seat time.
ConeDodger
post Nov 21 2011, 10:06 AM
Post #318
Apex killer!
Randal, this car will always be a compromise. My vision for it doesn't include making it more race car... I want to street drive it, take it to the occasional concours and win, and do track days and autocross with it. I want my wife to get in and take a ride. Your car is immaculate but Yopu would never climb in for a ride... (IMG:style_emoticons/default/sad.gif)
I hope to build a purpose built 'race' car with a partner. Maybe Mark...
I agree completely though, that last sweeper that extends the full length of the lot had me hard on the hammer and trying to hold it together in that 'stupid' last section of the course at the finish... I have to get used to not using all of that power... (IMG:style_emoticons/default/biggrin.gif)
Randal
post Nov 21 2011, 10:12 AM
Post #319
QUOTE(ConeDodger @ Nov 21 2011, 08:06 AM) *
I agree with you Rob.
Having a nice car and keeping it that way is a great way to go. Getting to drive on the street is a joy, which you can't do with a race car.
And when you want to AutoX or track the car just throw on a set of 205 Hoosiers and you'll be blow away how well it handles. In fact I think the Hoosiers got up to operating temperature faster than anything else I've used. And when you get adhesive grip it's something.
Eric_Shea
post Nov 21 2011, 10:14 AM
Post #320
PMB Performance
Looks like fun.
Congratulations guys.
- Lo-Fi Version Time is now: 23rd November 2024 - 05:07 PM
