V8 Grief, Now what do I do? |
NoPorsche |
May 18 2004, 03:24 PM
Newbie Group: Members Posts: 16 Joined: 11-September 03 From: Sac., Ca Member No.: 1,144 |
QUOTE The only year that had a mass produced 302 was the 69 Z28. Anything before that was the 327 destroked. Actually, 1967 (602 cars built, plus extra engines), 1968 (1800+ cars built) and 1969 Z/28s (20,000+ cars built) ALL had 302s. Each year used a block that was common to 302, 327 and 350, even 1969, where those three engine sizes could be found with the same casting number on the block. Just depended on what crank the factory wanted to install. The 69 did use a 4-bolt version of the block, but so did some of the 350s. The 67 and 68 versions were given an engine code of "MO", while the 69 was coded the "DZ"... On the 305 heads, the lower edge of the head is also differently shaped from most other Chevy heads. It has a "scalloped" shape to the outer edge where the lower head bolts go (visible in that photo). I have heard that this was only used on the 305s... Sorry to hear about the problems with the engine. I imagine now that the motor is out, and at a shop (3rd party), you are probably out of luck. I would think that the dealer doesn't want to pay, he will likely just say the engine in there was the 383, and either you or the other shop are lying... I hope the best works out for you... |
Howard |
May 18 2004, 04:22 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Thanks to all for the advice. I am now the proud owner of a brand new Mr. Goodwrench 350. Not rebuilt, remanufactured, resurrected, but actually new, local dealer delivered to wrench for $1300. Would have been $100 less with core. Ain't it purty?350
It is soooooooooo stock. Will let you all know what happened on legal end with seller as soon as it's resolved. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:18 AM |
