Cool replacement parts I have in the works..., LED bulbs,Halogen fog light bulbs, seals |
Qarl |
Jun 18 2004, 12:22 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have finally sourced and confirmed production of LED replacement bulbs for the backlighting of the gauges. I am getting my test set early next week and I will post photos of their effectiveness.
They will be compatible with the varying voltage of our electrical system, but will most likely not have brightness control with the headlight switch. But, we want brighter gauges, right? No more yellowish lighting! They will last longer and be cooler as well. The good news is that they are wide angle (due to the inverted lense on the top) and they diffuse light sideways instead of straight ahead). Cost should be reasonable, per bulb. $2.50 or so. If there are 5 bulbs for lighting in the set of 3 gauges, it should be pretty good bang for the buck! It will still take 45 days or so to get the bulk quantity order in, so I won't take orders yet. But I want to let you know they are coming? (IMG:http://www.my914-6.com/porscheba7s.jpg) (IMG:http://www.my914-6.com/red.jpg) (IMG:http://www.my914-6.com/blue.jpg) I can also get yellow and green, but I don't think the demand will be high enough for these colors. I have also inquired about having reasonably priced 55 watt Halogen fog light bulbs with the correct base made for the factory fog lights assemblies. I am awaiting the price quotes. These will fit in the stock housing and wil be significantly brighter than the stock 35 watt bulbs. These used to be available from a company in England for around $30 a pair or something, but supposedly aren't available any longer. When pricing and functionality are confirmed, I will post my usual thread and take orders. If you think you may be interested in any of the LED or foglight bulbs (and you have'nt responded to one of my earlier posts), add your name here and what you would be interested in. Also in the works... Tail light lense seals (easy to get made) Tail light housing seals (working on it). What do you think about these??? |
3d914 |
Jun 18 2004, 01:15 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Sounds cool Karl,
I actually might like the green, as it may go well in my Ravenna 914. I'm also intrested in the upgrade for driving lights. OT: Is your car finished yet? Enjoy! |
Qarl |
Jun 18 2004, 01:26 PM
My car is not finished. It is on hold as I have been busy with moving into the new house and other things.
It should start back up in a month or so. Regards, Karl |
GaroldShaffer |
Jun 18 2004, 02:03 PM
You bought another 914? Group: Benefactors Posts: 7,627 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Fog light bulbs & either the white or red led for the gauges si what I would be interested in.
Aaron Cox |
Jun 18 2004, 02:45 PM
interested in gauge lights (console too) clear,
and high power fog's |
PorscheTom |
Jun 18 2004, 03:12 PM
Will work for an Avatar. Group: Members Posts: 140 Joined: 12-May 04 From: Shingletown, CA Member No.: 2,057 |
I'm interested in the fog light bulbs (and a couple lenses if anyone has any spares - mine are both cracked) and either red or white gauge lighting - both the dash and console gauges.
Thanks for your work on this! |
Qarl |
Jun 18 2004, 03:22 PM
I don't have center console gauges.
What kind of bulbs do they use? Are they the same as the backlighting for the gauges? Can someone post a picture. Thanks! |
JWest |
Jun 18 2004, 04:29 PM
Cool.
The console gauges use the same bulbs and holders as the regular gauges. One light per gauge. |
Rouser |
Jun 18 2004, 05:02 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
A full set of white bulbs for dash and console gauges. Yep, that'll do it.
Korijo |
Jun 18 2004, 05:11 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
I got 3 extra sets of the seals. And 3 sets of direct replacement, 55W halogen bulbs for fogs.
Who wants some ? Bulbs : $50 Seals : $10 shipped |
StratPlayer |
Jun 18 2004, 05:34 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Great, complete set to the cluster and bulbs for 4 center console gauges. Green and white 2 sets
Qarl |
Jun 19 2004, 07:31 AM
Thanks for the replies.
Neal |
Jun 19 2004, 08:31 AM
Member Group: Members Posts: 300 Joined: 23-April 03 From: Sammamish, Washington Member No.: 605 |
I would want gauge lights (white and blue) and center console lights (white and blue), this is so I could effectivley change my mood on a whim.
Thanks Neal (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/wacko.gif) |
maf914 |
Jun 19 2004, 09:40 AM
Karl,
Good to see you back on the board. Is it purely coincidence that both you and Miles returned at the same time? Hmmm? (IMG:style_emoticons/default/laugh.gif) All your products look good. I'll order both type seals. And a set of clear instrument bulbs. Brighter rear bulbs sound good, too. Mike |
Qarl |
Jun 20 2004, 08:30 AM
Who's your Daddy?
jim912928 |
Jun 20 2004, 08:50 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I'll take a full set of gauge and console (white) lights when you have them...everything is out of the car now so timing could be great!
72914S |
Jun 20 2004, 10:10 AM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
The red ones for me !!! keep us informed.
SpecialK |
Jun 20 2004, 10:21 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
(IMG:style_emoticons/default/idea.gif) I'm thinking two sets of dash LED's (red), and one set of halogen bulbs.
Gint |
Jun 20 2004, 04:34 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I could go for one set of each color dash bulbs. That way, I can try 'em all and see which one I like the best. They're cheap enough.
URY914 |
Jun 20 2004, 08:12 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,027 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lo-Fi Version | Time is now: 27th September 2024 - 08:19 AM |
