Lexan rear window, Sources |
Qarl |
Jun 23 2004, 08:36 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
My rear window is the defogging kind. I will not be reinstalling the defogging glass into the car.
I am thinking of replacing the rear window with Lexan. I know a while back there was discussion of windshields and certain companies that offer scratch resistant coatings, blah blah blah. Anyone done this? I'd like to have the rear window, both lighter in weight, and coated so it won't show swirls and scratches. Thanks! Karl |
seanery |
Jun 23 2004, 08:47 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I don't think it's worth the hassle for you Karl. If it were a race car then it may, but for a street car it'll be a source of aggravation.
campbellcj |
Jun 23 2004, 08:49 PM
I can't Re Member Group: Members Posts: 4,574 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I just did it, with name-brand GE Lexan sourced from a local plastics specialist (ABC Plastics in Chatsworth/Canoga Park). One side apparently has UV protection but I did not see a need for any abrasion coating for a rear window...it should last fine with my use of the car.
One key thing per the guy at the shop is to never use chemicals including Windex or alcohol or ammonia to clean these materials; just a soft cotton cloth and water. A tiny bit of mild dish soap could be added if there is a lot of grime. I cut the shape with a sabre saw using the original glass as a template. On advice from Zois I clamped the lexan to some 1/2 wood boards to help avoid vibrations and splintering while cutting. You also want to use certain types of blades to avoid melting the material or getting a jagged cut...but the specifics (tooth count) evade me at the moment. Since the edge is not really visible anyway when installed in the car, the cut does not need to be perfect by any means (mine wasn't). |
GWN7 |
Jun 23 2004, 09:57 PM
A buddy of mine makes splash guards for boats out of lexan (they stop the waves from coming over the back). Besides the advise above...you can usually sourse it from specialty plastics places close by your place (yellow pages). They can cut it to the basic shape for you if you want. New Lexan can be cut in a shear and bent in a brake. Don't try it with old scratched stuff or you will end up with shards. (IMG:style_emoticons/default/smile.gif)
Scott Carlberg |
Jun 24 2004, 02:14 PM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Lo-Fi Version | Time is now: 27th September 2024 - 08:21 AM |
