My v8 conversion thread, With pics, progress, questions ect!! |
Andyrew |
Jul 8 2004, 07:26 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Cylander wear.. Not bad
Oh ya.. 1500th post.. I feel like a whore... (IMG:style_emoticons/default/wink.gif) Attached image(s) |
Andyrew |
Jul 8 2004, 07:27 PM
Stock exhaust, I think I'll use it for now. Give me a little more room to play with.
Andyrew |
Jul 8 2004, 07:28 PM
Newish fuel pump. I think I'll use it! Get rid of some electrical...
Andyrew |
Jul 8 2004, 07:29 PM
Head...
Andyrew |
Gota lap the heads or get a valve job (tehehe)
Andyrew |
Jul 8 2004, 07:30 PM
heads and intake manifold
Andyrew |
Dirty piston
Andyrew |
Jul 8 2004, 07:31 PM
Anyone want me to detail their car?
Clean piston Attached image(s) |
Andyrew |
Jul 8 2004, 07:32 PM
there so many of them!
drew365 |
Good luck Andrew. Looks like you just accounted for your spare time for a while.
Andyrew |
Jul 8 2004, 07:33 PM
Sexy aint it!
radiator with 944 twin fans.. I think the'll work fine Attached image(s) |
Andyrew |
Jul 8 2004, 07:34 PM
Its interesting.. I like the texture of where the rust was better than the pure chrome!!
Too bad it takes like 20 years to make that kind of texture... Attached image(s) |
Andyrew |
Jul 8 2004, 07:36 PM
And finally valves!
whew.. Sorry andy/brad, admin team... Oh heck its only 2megs.. Thanks drew Andrew Attached image(s) |
MattR |
Jul 8 2004, 07:47 PM
QUOTE(Andyrew @ Jul 8 2004, 05:23 PM) Anyone decifer this? front of block.. inside It appears to be a GM code (IMG:style_emoticons/default/wacko.gif) . Nice find! Keep the pics coming! |
Andyrew |
Jul 8 2004, 08:02 PM
The next series of pics I could post would be my flare progress.. but im not gona do that yet...
Andrew |
86motoman |
Jul 8 2004, 08:09 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
Here is a site for all of your chevy numbers. http://www.mortec.com
(IMG:style_emoticons/default/biggrin.gif) |
smrz914 |
Jul 8 2004, 08:17 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
Andrew you will probably have to use an elecrtic pump depending on how you mount the alternator and water pump. BTW very nice find on the engine. And if you do use a electric pump put it up front.
skline |
Jul 8 2004, 08:23 PM
Ok, First off, the pistons are standard GM pistons, the cross hatching on the cylinders tells me it has been bored at least once, but not worn much since, the black on teh camshaft tells me that it doesnt have that many miles on it40 to 50k, the block is for sure a factory 4 bolt main block so it is a 350, the numbers you were referring to mean the engine was made in 4 of 83, what year car did you say it was in? If you give me the number stamped on the front pad on the block in front of the head and behind the alternator, I can tell you what the engine was originally installed in and with what options ie: HP rating, transmission, with or without A/C and so on. Also give me the casting number off the head and I can see what that is also. If they are 305 heads, you got lucky, they have the smaller chambers for higher compression, mine are 55cc, stock they run 58cc. Mine have been modified with larger valves which made the chambers smaller. Anything I can do to help you get it up ad going, let me know.
Scott Oh BTW, I worked for Chevrolet back in the 70's as an automatic transmission line mechanic. |
skline |
Jul 8 2004, 08:33 PM
Here is the fuel pump I am going to install. It was graciously donated by a club member. You cant run the stock fuel pump with the water pump or alternator mounted the way Renegade does.
Andyrew |
Jul 8 2004, 09:12 PM
I cant run the stock alternator the way its mounted from the factory, alrighty thats peachy with me.. Why cant I run the stock fuel pump? Its so perfect... (whine)
Scott.. The engine was in a 84 caprice... no clue why. Engine number.. ok C5F368754 VO219TJH Heads 333882.....74-80...350/400......76cc chambers Engine block 3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 http://www.914world.com/bbs2/index.php?act...70&st=40&hl=350 Need anything else? I'd like to know what the numbers are for it.. Andrew |
Lo-Fi Version | Time is now: 23rd November 2024 - 05:09 AM |
