Performance Front and Rear Suspension Parts |
Britain Smith |
Oct 26 2011, 09:02 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Several High Performance parts off my 914. All of these parts have very low mileage as the car is a dedicated AX car. All the parts located in Fullerton, CA area, local Pick-up preferred. If you would like items shipped, please inquired regarding shipping costs.
Front: Bilstein Struts with Raised Spindles, 3.5" Caliper Spacing, 911 Hubs, 45mm Studs w/ Lugs, and Rebuilt Bilstien shocks: SOLD S-Calipers with Stainless Pistons and Fresh Braided Brake Lines: $700 SC Cross-drilled Rotors: $100 pair (new $127 each) (IMG:http://www.914world.com/bbs2/uploads_offsite/a6.sphotos.ak.fbcdn.net-364-1319684530.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/a2.sphotos.ak.fbcdn.net-364-1319684531.3.jpg) Elephant Racing Bump-Steer Kit: SOLD Wevo Camberking Strut Mounts (used less than 1 month): SOLD Control Arms with Needle Bearings, 21mm Torsion Bars, Sway-Bar Tabs and Fresh Ball Joints. Steering Rack with Turbo Tie-Rod Ends and Rothsport Racing Bump Steer Kit and Steel Cross-brace. Billet Steering Biscuit to correct steering u-joint angle with rack spacer (Control Arms have been seam welded and machined to fit inside 15" Fuchs): SOLD Tarrett Engineering 22mm Hollow Sway-Bar with Fresh Bushings: SOLD Rear: Seam-Welded and Trimmed Trailing Arms with Needle Bearings, Fresh Wheel Bearings, and 944 Turbo CV Conversion including 100mm 6-Bolt CV Joints, machined 914 Axles, 911 ('69-73) Hubs and 60mm Studs w/ Lugs. (brackets for e-brakes have been removed): $650 (Needle Bearing are $400 new) (IMG:http://www.914world.com/bbs2/uploads_offsite/a5.sphotos.ak.fbcdn.net-364-1319684537.10.jpg) SC Rear M-Calipers and SC Rotors: $100 All prices are listed without Shipping costs. I accept payment via paypal. Offers on package deals accepted. -Britain |
bdstone914 |
Oct 27 2011, 07:58 AM
bdstone914 Group: Members Posts: 4,708 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Why are you selling off all that nice suspension stuff?
Are you parting out the car or getting better parts? Bruce |
Britain Smith |
Oct 27 2011, 09:59 AM
Britain Smith |
Oct 27 2011, 10:15 AM
The following parts have been sold:
Bilstein Struts w/ inserts Elephant Bump-Steer Kit Tarrett Sway Bar Front Control Arms w/ Torsion Bars Steering Rack w/ Billet Biscuit |
jpnovak |
Oct 27 2011, 10:20 AM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
What about the rear coil-over setup? What is the spring-rate?
Britain Smith |
Oct 27 2011, 10:31 AM
Somehow I accidentally got two threads going...oh well.
Rebuilt Bilstien Shocks with Coleman Threaded Collars, Aluminum Hats, 275lb and 325lb springs: $450 (IMG:http://www.914world.com/bbs2/uploads_offsite/a3.sphotos.ak.fbcdn.net-364-1319684988.1.jpg) |
Britain Smith |
Oct 28 2011, 11:13 AM
CamberKing Sold.
Britain Smith |
Nov 10 2011, 02:48 PM
All that is left are the S-Calipers, Rear Trailing arms with 944 Turbo Axle Conversion, Rear Shocks with 275lb and 325lb Springs and Rear Brakes/Rotors.
_Britain |
LotusJoe |
Nov 10 2011, 04:03 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Somehow I accidentally got two threads going...oh well. Rebuilt Bilstien Shocks with Coleman Threaded Collars, Aluminum Hats, 275lb and 325lb springs: $450 (IMG:http://www.914world.com/bbs2/uploads_offsite/a3.sphotos.ak.fbcdn.net-364-1319684988.1.jpg) PM sent on rear shocks and coil overs |
Lo-Fi Version | Time is now: 23rd November 2024 - 05:09 AM |
